Land rover 110 rear brake disc WARPED AGAIN
mendiplogs
Load proportioning valve seized ? I have same on rear of my disco 2 van few thousand miles pedal pulsing up and down but not coming through steering. I think genuine parts may be on order soon as the mintex stuff may not be as good noticed the discs rust quicker when parked up sort of points to quality of steel.
then it doesnt have one, they are usually for soft jappy types anyway, landrovers dont need them.. sounds like a caliper at fault, but needs disks/pads at same time obviously, or put up with a lovely foot massage every time you brake..
Edited by armchairarborist
no reason given..
you wont find one on a defender.
you carrying alot of weight all the time? that will prematurely wear the brakes. are you in very dirty conditions ?Imerys get abiout 2 weeks to a set of discs in the clay pits!!!They are usually about 2mm thick when they ahve finished with them!!! (silica everywhere)
First you need to establish if it is the rear brakes that are warped.
You need to clamp off the flexi pipe gently that runs from the body to the rear axle and try it again, this will make it so you are running on front brakes only and if the wobble goes then it is the rear and obviously if it doesn't it is the front discs.
I have never seen rear discs warp it is normally always the front because they bear the brunt of the braking effort. Normally caused by going down long descents on brakes alone without using engine braking
If it is your rear brakes then it could be something to do with your master cylinder which on defenders is responsible for distributing the braking force as they dont have load sensing valves
Are the brake discs "blued" or pads cracked and glazed as if they have been over heated etc etc, look for the tell tale signs
