Call them what you will but they been around a while and I know some use them and some dont.
I have been looking for one and found what I think is a good one but would like to know what you guys use before I commit to getting one and spending £69
I like the "TECH-TACH TT-20K" which used a 9v battery as opposed to the smaller "FAST-TACH" which uses a small round whatsit battery. The unit is smaller so a plus but I think the bigger TT-20K will last longer (a personal thing and both the same price)
Here is the web site Design Technologies. Hand-Held economical tachometers. Wireless tachometers.
Any help advice would be more than welcome:confused1:
The TECH-TACH TT-20K, only measures up to 10,000 rpm, no good for most chainsaws, as they run a 14,000 rpm or there abouts
No it doesnt, well mine goes higher than that anyway, upto 19,000rpm I think.
There is always somebody that has to be different......
Anyway most but NOT all rev at about the 14,000 mark, or they used to when i last brought a new saw (admittedly that was 8 years ago).
No I meant the tach not the saw.
Heres a pic from the other thread.
Says tach will do 19,900rpm.
[ATTACH]41938[/ATTACH]
I can not argue with that. But following the link, the blurb says the tachometer go up to 10,000 rpm. I just says what i see.
where did you read that, not the TT-20K that's for sure.
I looked into this long and hard and finaly sent for one, if it only went to 14k I wouldnt have bothered, read again my friend I think you had it wrong:thumbup1:
