I need a pump to lift water from below ground (a well) trouble is there are many pumps out there, but I need to know the most suitable. A high flow-rate is not essential, but must be capable of more then a dribble. A leccy one would be best I think.
I'm guessing I need a clear-water submersible pump, trouble is I do not understand the terminology I'm reading:blushing: ie max grain size, does that mean the grit in the water? In the catalogue it mentions residual current circuit breaker must be used on some models:confused1: I cut trees, I'm no sparky!!
If the water is clean then yep a clear one would do you. What is the water being used for/why is it being pumped?
Max grain size is the solid object that will go through the pump, ie at our cycle speedway track lumps of shale that go down into the drain.
Basically if your mixing electricity and water a circuit breaker is a good idea it means if something goes wrong the electric trips out. Current regs mean that any socket that is likely to be used outside should have one inbuilt. There only a fiver or so and just plug into a normal socket.
R
Anything you use outside ought to have a RCD.
It’s one of those quick trip out boxes that stops you getting a jolt if it goes wrong
If you want a more installed solution check out the Clarke range, fairly reasonably priced. I'd go for a self priming one.
Booster & Centrifugal Water Pumps - Machine Mart
Advantage is that the pump is kept at ground level, drop a pipe down with a foot valve (£4) to retain water in the pipe - means there's no wait for water.
I have one of these for the 'clean end' of my septic tank.
