My first attempt at an Owl
I have tried a couple of mushrooms that I was quite pleased with so thought I would give something abit more challenging a go. I'm quite pleased with the result but know there is a lot that can be improved on future attempts. I used a blow torch to bring out the texture in the feathers. All done with a top handle.
Let me know what you think...:thumbup1:
Cheers Gary
Looks very good for first attempt, did it hit a tree when it was flying face looks abit flat :001_tt2:
Thanks Ian , I know what you are saying about the face. I'm thinking of getting an angle grinder with a sanding disk on so I can get more curves into it. :thumbup:
I wonder if you'll get any Piptopo..........Oooops, wrong thread :blushing:
I think it's actually pretty good.
Can't see from this angle, did you carve much relief on the wings?
Cheers MonkeyD, I ran the edge of the chain over the wing areas and it gave it quite a good feathered effect, especially after running the blow torch over it. Not sure if that's what you mean by relief??:blushing:
I thought it was a rabbit at first glance, perhaps the head should be a bit further forward.
EDIT; I just had another look, I think it's the wings being too thick that stops it being instantly recognisable to me. If they were thinner and maybe swept back a bit at the top it might give more impression of movement.
Edited by Catweazle
