It'll be fine. I've been hammering mine for nearly 3 years and its still going.
There are good arguments for spending thousands on kit, but it is not necessary.
If you want to cut hedges, it will cut a lot of hedges.
In my opinion, if you are after a trimmer, there are much better machines out there than Stihl.
If you want to make a nice tidy job on privet, tight trimmed conifer etc, i would steer well clear.
If you are not bothered about finish, get a stihl cutter, it will savage a thorn hedge but thats about it.
It will require spending more money though if you get a REAL hedge trimmer.
I've bought this as a stop gap doing peoples Privets while i struggle to find groundie work, I hope that it will do the job for now, Thanks pro gard
Cheers Paulsbrash.!
Whats a real hedge cutter out of interest?
No, no, no! You miss quote me!
A real hedge cutter is a stihl HS81r
A real hedge trimmer is a robin(no longer available unfortunately) or Echo HC331
Arbclimber, seriously is the hs45 a bag of sh**e????
No mate, its not a pile of rubbish. If you are on a budget it will do few jobs for you and probably be fine. It is a domestic tool though, vibes are high and tooth gap is quite small so you wont be cutting anything big with it.
18" is very very small for a hedgecutter. I try to be packing at least 30" at all times:biggrin: Being so short, it will be very limited.
Anyway, its cheap as chips so why not give it a go.:thumbup1:
As far as business card are concerned, go see your local printer.
