there may be an other option two tanks one for red other for white the change over has to be outside run white on road red for hiab etc i know someone in colne with a recovery truck set up this way
Unfortunately this is no longer legal:cussing:
vegetable oil (SVO) is subject to the full amount of duty and is not included in the 2500L per year.
Vegetable oil that has undergone transesterification to split the triglycerides (fatty acid chains) from the bigger main glycerol molecule of the Vegetable oil, as a result the triglycerides witch are the bit that burns witch are much smaller than the main molecule from witch they were split so the end product is much less viscous than SVO and on a par with normal diesel, as a result it is not so affected by cold and conforms to the same specification as diesel, thus can replace it so is called bio-diesel as it’s a direct replacement and as such the 1st 2500L per year are duty free.
