  • Replies 24
It's an 18-35mm lens on an eos 300D.
The pics above were taken with a canon powershot which I bought 2nd hand and struggle with!
You might consider getting a set of close-up lens (supplementary lens) for your lens.
Each is a screw-on 'addition' to your own lens. They're available in different strengths and if you're experimenting without a big budget - they might be worth a look.
Dee
be sure it isnt a false morel though!
just to make you work for it!
I did see that on the next page - one is tasty and the other will kill you, or - if you're lucky - give you cancer!
I inadvertently confirmed the ID on this one by knocking the top off with my foot, thinking it was a loose fruit body of Sparassis - this revealed a hollow tubular stem, which I poked a stick into and stuck the cap back on - hence the jaunty angle.:biggrin:
Thanks Dee, I used to have one of things years ago, I might get one again once I've got my head around the basics.:001_smile:
lol one of my lucidum shots was not on "that" tree origionaly! was moved to a more photgenic place!:laugh1:
