Tin sheds for storing timber
Johny Walker
the only way condensation can form is by warm air hitting a cold surface' if you are moving that warm air out of the shed and equallising the temperature inside and out its impossible for it to form unless the tin sheet is very much colder than its suurounding ait temp theonly other way is if the groung temp inside the dshed is heating up still air inside
Dean, I would say that you will always get condensation as the metal is a far better conductor of heat than air. In the evening especially, the metal will radiate its heat and become much colder than the ambient air temperature in quite a short period of time. Do you agree?
  • Replies 21
