Full Chisel?
Tom D
  • Replies 20
agreed, but not as disapointed as dinking a new full chisel:cussing::cussing:
sharpening skills...ive found i can make a re sharpend chisell chainout cut a new a new chain...its just when you keep blunting the ****a it gets anoying...i got a semi chisel today....that could be made to sound perverted but thing is i know im gona be disapionted when i put it on the 372
well why dont you put it on a proper saw then:wave:
i personnally wont buy anything else other than a full chisel, if im cutting bad timber i find a part worn or a damaged chain and just use that.
why do new chains always manage to find the only nail in a 40foot stem?:cussing::cussing::cussing:
Clean wood chisel.
Dirty wood semi-chisel.
right tool for the right job
theres a greater risk of kick back/vibration from a full chisel on a low powered saw. :thumbsdown:
i guess thats a double, right tool for the right job, or right chain for the right saw:alberteinstein:
just the way it is! im gutted about buying a semi chisel but i got a lot of crappy wood to shift and the brand new chisel i brought for that bar was for a 16 " not a 20" so 4links short but as i said i got a lot timber thats ben sitting for 4+ years so probably for the best..thing is i find a slightly blunt chisel cuts like a sharp semi
Clean wood chisel.
Thats how I would have put it.
Arb work seems to have more debris/chain contact than forestry. I specify semi from my chain man but have some full as well for most saws in the fleet.
