Hi Guys thinking of replacing my fuelwood kindla it would seem fuelwoods new kindlet pro is 3 phase.Problem being havent got 3 phase is there a converter unit out there that would run it from single phase??It is 5.5kw so someone says need 11kw i havent a clue any advice most welcome
hi I run a 10kw bench planer which is 3 phase of a convertor,,,from my 240 ring,,,,,if you go on e-bay you`ll find em,,,,big blue box,,,transwave convertor,,,,,not cheap,,but the works,,you want a rotary one,,,,,,good luck,,,,,if you can afford the pro.kindlett you have no issues,,,,,lol
Hi mate, you need one of these. I am thinking of selling mine, as my new workshop has 3 phase, and i dint need it now. I think mine is about
5 to 6 KW rotary, bought from Transwave. I used it for running 4 different types wood working machines. Had no problems with it. You could try the add trader for second hand. Good luck looking.
Thanks for that i may well be interested if my deal comes off pm me if you are thinking of selling it :thumbup:
  • 3 weeks later...
I assume it is just the motor that is 3 phase and the rest of the machine is single phase.
I am an electrician, we used to convert 3 phase on gas burners by placing a capacitor accross 2 terminals of the electric motor. You will need to contact the motor manufacturer for the correct size capacitor and wiring diagram. Get the technical department to email you the details. The capacitor throws the voltage out of phase to create a false 3 phase supply. You should be able to buy the capacitor from somebody such as CPC, Radio Spares or Maplin.
Regards Ian
