Yes I have used a 230 sometime ago and agreed it was quite an improvement in the hopper and feed roller area, the 150 has quite a narrow hopper as it leads to.the rollers. The biggest gripe about a 150 is the god forsaken bearings and having to take it all apart to replace, that and my track base is pretty well past it.
Edited by markieg31
When employed we had the 6inch safe track, Isuzu motor, great wee machine, far better than a 150.
im assuming whatever you’re looking at you’ll want varitrack?
Sounds like the 16-23 SafeTrack  ?
Unfortunately no longer in production due to the engine emissions regs , a brilliant chipper if you can track one down although most owners tended to keep hold of them.
I agree in it being potentially better than the AT150 which had a fixed track base.
The Tracked EVO 165 is a very capable 6" machine.
Used a Forst TR6 and TR8 both are great as usual an 8 inch machine is so much more productive at the expense of being easy to get into places. The vari track 8 inch forst maybe the quickest chipping machine I've used. I've seen a lot of broken forsts in my time though so I wouldn't get one.
Greenmech 165 Evo I think is the best of the 230 size chippers. The 205 Evo on tracks is great but it feels like a big unit in the woods tracking about .
Jenson 540 is again an slightly bigger than 6" but a great machine. The rocking track base for level is a bit crap Vs veritrsck. Dealer backup is shocking.
Check out the greenmech it's great. The bigger timberwolf like the 280 have variable track speed which is a good send it you use it to go rough places. Not sure if it's an option on a 230 tracked as I've not used one.
