Hello peeps,
Now I’ve changed my bar & chain combo a few times to go longer and shorter, no issues.
What I am curious about is whether I can fit a slightly different GAUGE bar & chain if the drive sprocket size matches the saw?
For example can a 3/8 0.050 (1.3mm) bar and chain be swapped out for a 3/8 0.043 (1.1mm) bar & chain without issues?
My mind tells me it should all work and would just require the bar stud nuts to come further down the threads to snug up the 0.2mm thinner bar.
Am I missing something? 🤷‍♂️
17 minutes ago, Mik the Miller said:
The bar, chain and sprocket (spur or rim) must all match.
A narrower drive link will draw through a wider channel but it can catch on the walls and it's not something I would recommend.
Yeah, I’m definitely not contemplating sticking a smaller chain in a wider bar, but from what you’ve said (if I understand correctly) if the drive sprocket size is correct, and the bar and chain match, it’s all good, right?
You're correct, yes. Drive sprockets only have pitch, so same one for different gauge chains. Bar and chain match pitch and gauge.
Not recommended to swap new chains onto old sprockets though, keep an eye on that. They wear together as a pair, so if you put a new chain on an old sprocket it will not make proper contact on the wear points and can mangle the chain, that's whether it's same gauge or not.
Edited by Dan Maynard
1 hour ago, Mark_Skyland said:
As above its worth replacing it with a new drive sprocket on unless its fairly new with no wear marks.
Thank you Dan and Mark! 🙏
Fortunately the saws I’m contemplating doing this swap on are both brand new, so no wear or tear on either drive sprocket. I appreciate your help!
I am lead to believe the 1.1mm bars can be a bit fragile (prone to bend) and the chains can be a bit of a bugger to sharpen, but let’s give it a go! 👍🏻😃
My narrow gauge bars are only up to 10" long so not been fragile particularly, more likely a problem as they get longer I guess. Sharpening is fine and not really depending on gauge, that's more a problem with the smaller 1/4 pitch.
Only other thing to keep an eye on is that both 3/8 and 3/8 LP exist (low profile). It's most likely that both 1.1 and 1.3 chains you have are actually 3/8LP as on smaller saws, and if you stick with manufacturer parts it'll be fine.
If you start buying chain on eBay for example it's possible to be caught out though, as you can buy 3/8 chain in 1.3 (0.050) . More popular in the US though, the vast majority of 3/8 1.3 in Europe is going to be LP. Each manufacturer has their own way of describing, so Oregon LP is type 90 or 91, Stihl is Picco etc.
