On 23/08/2025 at 08:21, kram said:
What do you use or recommend?
Most arb ladders I've seen or used , have been past their best and I'd like to get my own for the odd hedge job I might get to do on my own - so Im after a decent one that can be used as an A frame.
Transport will be by car roof rack, so I will be limited in length.
Henchman if you want a tripod.
Halo if you want an extension ladder.
Nope I quite like the ones I got, one of my best arb purchases. They are exceptionally stable as an A frame, light and compact for the roof rack. 10 meters fully extended if I remember correctly, 5 meter as A frame.
Only thing I dislike is when using extended with the bottom type sections leaning against a tree, they are too wide and I dont know how strong the rungs are like that.
Screenshot_2025-12-31-20-14-35-105_com_miui.gallery.thumb.jpg.f29d6a45aab800671d88b1c476c25349.jpg
But in that example I didnt need the extra height, could have removed the end section. Anyway it worked.
The other disadvantage is in the example above, if you had it fully extended, a groundman cant easily lower the upper section without flopping the ladder down to the ground, as the adjuster 12 rungs up in that pic.
Edited by kram
