Hi All,
I have a Timberwolf 190 (not turbo) 2004
engine runs well everything seems to be good except the feed rollers won’t feed, although they run in reverse.
I have checked the throttle cable to see if it is not going to full throttle but this is ok,
I have checked the solenoids tried reversing them to see if one is not working but it is still the same,
any ideas would be appreciated
thank you
Had a problem with my 150 like that was the plug underneath hopper had worked it's way apart, maybe worth checking all plugs, and spray a bit of WD40 in them, or any other make.
When you say solenoid are you on about switchs on hopper. Or hydraulic solenoid.
Edited by woody paul
Have you checked fan belt for tightness as some use alternator to sense engine speed.
You can bypass stress control by connecting the 2 beside the stress unit. Also swap out the relay besides the stress unit, it's a standard relay.
Other than that check all wiring, switches and connectors,  that they are doing what they are supposed to do.
Switches are, forward/reverse/stop and safety bar.
