14 hours ago, Ramsay said:
Will give it a shot.
Yup, if its an old saw the carb could probably do with a good clean out with carb spray and new diaphragms.  There are plenty of youtube videos about this. Clean the screen, jets and check the metering arm height.
Thanks. Done quite a few carb rebuilds, but was hoping to save a job. Will add to the list. 😊
On 28/01/2025 at 13:45, Ramsay said:
I’ve replaced the spark plug and tried full choke, half choke and no choke, with it often starting best on no choke.
….best on no choke….
What does that mean?
I bet it means choke for a dozen pulls, frustration, then trying every other control switch option….🙂🙂🙂
Or am I wrong and it means no choke from first pull?
Have you tried 3 pulls on full choke then switching to ‘half choke’ irrespective of it popping on full choke?
You can flood them if you're being a bit over jealous on the choke and pulling the cord.
As per bmp, half choke after 1-2 pulls or even off and a few pulls to thin out the mixture as you'll probably find the plug sopping wet.
