Attach the cable and do the ‘stepping down cut’ in the diagram as low a possible, and use the tractor winch to pull it backwards.
I always arrange the dead men laying in the same direction of the intended pull, not 90 degrees to it as in the diagram.
Expand
Yes good shout. Making it slide-y instead of roll-y, I like it. Thanks
  On 14/01/2025 at 19:04, woody paul said:
I would just put winch rope up it as high as possible pull it back upright and then fell if there's room too.
Expand
I would have done that but as you never get it back completely upright I would fell it sideways but then I was always wanting to preserve the maximum amount of saleable sawlog.
Most times when we could get the tractor up close we would cut it off at the stump, winch it high up to the butt plate and drive away.
Got it down this morning, came off really well. The root plate mostly sat back in place, but quite slowly. No fences or pheasant feeders damaged. Good result. Thanks for the replies 👌
  • Like 10
  • Thanks 3
Read more
