Ascender's
cordwood
Is there anyone on here, or anything on the net or in any book's that can demonstrate the correct use of ascender's. I've borrowed a set from a mate who never has used them and isn't sure how to either !
there are two single's, a left and a right. And also there is a double, i've had a quick play but the way i set them up is definately wrong any advice would be great!!
I have been loaned a pair of Kong double accendors, I just use them to footlock a doubled line into the tree.
I don't back them up with a knot, I just use them as they are, with a sling larks footed to the accendors then larksfooted to a normal 3 way biner to my harness.
The Kongs have a latch to hold open the cams to make installing the rope easier, when closed the latch also prevents the cams from opening far enough for the rope to drop out. Still its a good idea to use a small accesory biner in the properly postioned hole as a back up to preventing the cams open.
Also i've seen others use 2 shackle between both halfs of the double accendor, this is back up in the unlikly event that the rivets should fail and cause the 2 parts of the accendor to seperate.
