help with greenmech cs100
naturarbo
Carefully cut the bearings off with a grinder. No point spending loads of time removing bearings in one piece that are knackered.
If you've "modified" the taper lock bush, chuck that in the bin with the old bearings also.
Check the drum is true, no cracking on either the drum or the housing. Refit your new bearings, new taper lock bush and jobs a good un. Set the blade - anvil gap with the setting tool provided by GreenMech. Double check the anvil - blade gap on both blades rather than just one.
Should be about 2 hours work in total.
Edited by GA Groundcare
