10 hours ago, JBH said:
The RRP extended with a small tape sling is worth trying. Drt it is like a mechanical blakes with reduced risk of catching the bird, extra slack distance to feed through when scrambling around obstacles, more ergonomic tending the device, can swing it around your body/ swivel it, when coming back from limb walks you just use it in the style of a hand ascender
This sounds like an interesting idea, I've been thinking about hand ascender but don't want more gear.
34 minutes ago, JBH said:
I saw Paul Poytner discuss extension tethers on his website and it definitely is worth giving it a try
Do you have a link? Sounds interesting.
59 minutes ago, Rich Rule said:
WWW.THEWOODENHAND.COM
Thank you! Super interesting. This is a good read:
At the end he mentions piggy backing anchor points, what would be a simple and retrievable way of doing that?
Edit: I guess he means using two ropes but would be cool to do it on a single rope as well.
Edited by Hank
Yes, I think he is just on about connecting the two anchors for simple retrieval.
His American Clacker anchor is interesting for two rope retrieval. If the connecting ring had a low enough breaking load to separate the two systems in event of anchor failure then it might be a bombproof choice for UK climbing regs (if anyone actually bothers with two ropes)
