Hello all
I've got a Hayter Harrier 48pro (2021 model i believe), its developed a really annoying rattle which I think is only really when blades are engaged (has bbc clutch so deadmans handle disengages blades without cutting engine).
Seems to cut and drive fine.
Before I start stripping it apart can anyone tell me what to look out for?  Is there any common problems with these?  May save some time if I can go straight to the issue!
Many thanks
11 minutes ago, openspaceman said:
@lurkalot runs a forum
THEGARDENMACHINERYFORUM.CO.UK
This board is for all lawnmowers including ride on mowers. If you're looking for advice on how to fix your lawnmower, or...
Ah that looks good, will have a browse or post on there.  Many thanks
