Hi.  I’ve snapped both of the belts on my flail topper ATV120
I’ve managed to change one belt but unable to move it to the second location further back.
how do I get the second belt on
Any help is much appreciated
thanks
Think you got the wrong size belt, there should be a lot more lack.
But a tyre iron/screwdriver can be used to lift it up and roll in into the next groove as you turn over the engine obviously with the spark plug disconnected.
Edited by GarethM
Thanks. Rechecked order and it’s the correct one
taken off tensioner and still no joy
also used leavers, screwdrivers etc but no joy
didn’t know if I had to take a wheel off ?
if so which one. Top or bottom and can it be done
Re check it’s the right belt, there doesn’t look to be any slack for the tensioner to take up. If there is no slack they won’t last long!
Daft question, did you buy from a distributor or yourself?.
Just thinking you might have mixed up the OD and ID, so it's shorter 🙂
