Husky 32 solo 600
Dazlar
I have recently acquired a solo 600 which Huskvarna branded as a Husky 32, and I can’t get started as no spark, I have changed plug and and set points and coil spacing to manufactures recommend space, still no spark next is to replace the coil, this is where I have become stuck! I can’t find one, does anyone know where I may buy one from or know of an alternative chainsaw model coil that will fit?
I just cannot believe that coil is going to fit and work, the Husky 32 was indeed a Solo machine, we sold that back in the late 70s, I can’t even remember if it had points ignition ( could be wrong ) good luck anyway
On 30/04/2024 at 20:57, adw said:
We are showing our age now with points and condensers, I believe there was something called a mighty atom which you took the wire from the points and connected it to this small tablet and away they went like magic.
Yup, did a similar conversion on an old Dolmar with a Stihl "Tablet" and it all worked very well. Alchemy I believe!
