  On 03/04/2024 at 17:34, Mik the Miller said:
Not true ... paint will stick to a stainless steel.
You do need to get the shine off first though which you can do with a 200grit emery paper or a pickling paste and then use an 'etch' primer or direct to metal topcoat (Hammerite for example)
Expand
Are you sure you don't mean 2000 grit?
200 is going to make a mess of it.
  • 4 months later...
There's no problem getting a lasting coat of paint, I use Clearview, on single skin stainless pipe. The reason paint may not adhere so well to twinwall is the surface may not get to a high enough temperature  needed to fully cure it.
Read more
