As said a fag paper clearance, worth taking into consideration a tad of float on the rotor shaft bearings or bearing housings. There can be a small amount of wear in the bearings and or the bearing housing which will let the rotor walk, I always load the shaft towards the anvil when doing the clearances.
Bob
  • 10 months later...
2 hours ago, HNK said:
Hello,
Can you re-upload it? have been looking for the TP760 pdf online but could not find it
If you PM an email address I can send it, very little space left to upload.
Edited by openspaceman
