I had a 4wd one, was a great truck.
If I were you I’d just build a chip body for the back and get a potato fork, three bits of chipboard will do fine, then you can collapse it when you don’t need it.
It’ll take you 10 minutes to empty, save you thousands which you can put towards a decent truck.
And yes I did this with a hilux for a year or so back in the 90s
Yes this set up works well. I have had just this and a road tow chipper previously.
I had a thing called a load handler
LOADHANDLER.CO.UK
The Loadhandler is designed to simply and safely unload your pickup of logs, woodchip and much more It simply fits...
it worked well along with a potato fork. As you say 10 mins to empty what was about 2m3 of chip.
That may end up being the option i take.
Although a tipper has some benefits to it still.
but still curious of the 2wd models and there load capacity.
