Had blockage in our ST6, freed it, now both rollers are running very slow and then stopping, in both directions, feels like they've lost hydraulic pressure but levels are fine. Any ideas?
13 minutes ago, Excels1or said:
How would I check that mate?
If its like on the Jensen then there is a screw holding the cap on . If you take it off you can see if its corroded in there .
Corroded or scalding, usually you can buy the coil on its own.
If you have more than one coil you could swap it for another one to verify the problem and check fuses.
