Right....I am looking at putting a TV corner shelving unit in and am wondering if any of you fellas either can make one or can supply the cut timber for me to finish. Something like this: -
Custom Made Live Edge Shelf
The spec....90 degree corner with both sides being around 60cm making the front approximately 84.8528137424cm long ;), thickness around 55 - 75mm thick. Wood type - I like the Indian Rosewood (Sheesham) or Mango as they have a bit going on with the grain rather than it looking a bit uniform and sterile but they are a bit exotic so Elm, Walnut or perhaps Oak if there is a bit going on with its grain but open to other suggestions.
I am in Norfolk so pick up is probably easier unless you have a better idea. Just PM or discuss but will be looking for some rough pricing to start with to see if the idea holds up.
Cheers
