Stihl 009 oiling
Aled Hughes
Stihl 009 just wont oil, stripped pump if that's what you can call it. Blown through and cleaned out the feed pipe and no issues there. Blasted brake cleaner through the brass pipe which has the one way valve with no apparent blockage. I've replaced the diaphragm that has the attached rod too so im stumped. Anyone worked on one of these that can possibly tell me where in going wrong? Thanks
