Which flail to buy for a Sunward 25UF
Treeman123
I recently bought a femac for my 3.5 ton machine, haven't used it yet however i had to fit a case drain line to stop a pressure build up in the pump. You might have to do the same depending on the flail. Other than that i don't know much about them apart from you must have enough oil flow.
