LOLER inspector
TREES.SERVICES
If you go to the NPTC site below and search for a centre it should bring up NPTC centres local to you who can offer it. However the main issue is that there isn't that many assessors so it's finding out if you are in the right spot with easy access to an assessor and frequently run courses.
https://www.nptc.org.uk/qualificationschemedetail.aspx?id=576&back=qual
