TW 230 Rollers turn at any rpm/ no stress control
Hi everyone,
I have a TW 230 DHB, the stress control don't work and the roller rotates even on idle.
I've check all the belt.
Is a fault with the no stress box?
Three months ago, I had a short-circuit on a solenoid (directional valve coils). This incident will affected the no stress box?
Any idea of how to fix this?
Thanks
Had opposite to your problem last week on my 150 turned out to be wiring plug and socket under hopper. I hit a massive pot on the way to job and it dislodged connection.
Maybe worth checking all plugs and sockets.
Think you know it needs a new or reconditioned control module.
Sounds like something has goosed either a relay or something within the electronics with the surge, strange how it's not defaulting to a safe state of everything being off tho.
Did you replace the direction valve, just wondering if you did and didn't wire it correctly then getting feedback ?.
