I hope this is the right section to post this. So my DMM steel thimble cord used as part of Tefuelberger Pulley Saver failed LOLER. So rather than spend £70 on a whole new one, I thought I'd save a bit and just put new 8mm cord into the original steel thimble.
Does anyone know a method for getting it in. It's so tight, I can't push the cord into the hole. Is there a special tool I need to use?
Thanks
If its the original thimble from the pulley saver I think it's 7mm (ocean dyneema rather than ocean polyester).
Weird that that part of the pulley saver failed a LOLER inspection as its just used for retrieval and shouldn't be particularly high wear. Did you nick it with a saw?
  • 8 months later...
Depends on configuration, the thimble loop can absolutely be a piece of life support though and it's definitely correct for it to be LOLER'd. You're right though, it's a thinner cord, might even be 6mm ocean dyneema, it also has a 2 year lifespan rather I believe.
Never seen this configuration before! I should read the instructions more.
Guess @wjotner could buy a replacement thimble loop?
HONEYBROS.COM
Teufelberger Ocean Polyester Loop T from Honey Brothers. The largest equipment specialist in the tree care industry.
