Hi there, excuse my ignorance my st6 D was working perfect. Turned it off...i then moved it in garden and went to chip more bit it won't go forward. Will go back no problem but not forward.. Not blocked as I was chipping very small kindling
Has the throttle lever come slack so doesn’t stay on full revs in effect making the no stress kick in before you start?
also check the light (red or green from memory) on the solenoid comes on when you push the feed direction buttons
