Looking for recommendations of a replacement for a Kohler magnum 12, as fitted to Wheel horse garden tractors
1 1/8 shaft size
or is it possible to get a sleeve to up the shaft size? Seems 1” / 25mm is common on Loncin motors
any help much appreciated
We used to sleeve smaller motor shafts quite a bit in automation, to get things matching up. I guess the problem here would be the drive is probably through a key, and a sleeve would only be 1/16 wall thickness.
Is it a pulley drive? Might be possible to buy new pulley with same outer but correct hole.
