Good evening a bit of help is required. I've a 560xp that I start the usual way choke it fired, push lever down to fast idle, it fires and idles on that but when you blip the throttle nothing changes it's as if it's continuously on fast idle. Took exhaust off and lots of excess fuel there which is exactly as I suspected. Any help appreciated thank you
  • Replies 27
Has someone had the carb elbow off and not meshed the carb to choke lever on reassembly.
On the saw before starting it, you lift the choke lever, push it back on to fast idle setting and open the throttle, do you hear a slight click as the fast idle is released?
No I don't as I compared that to my 562 and thought something isn't right in that area.
Well it sounds like the fast idle is stuck on somehow. I have seen bits of twig have this sort of effect on carb linkages but it sounds like you need to take a look at at the carb and throttle linkage.
Can you circle where I should concentrate on, not my actual carb thanks
Just looked at one I have on the bench and if you actuate the choke - second picture lever on the left and then take it off so the choke is open again, when you rotate the black plastic assembly (bottom pic) the throttle cable is attached to, the fast idle should click off with an audible click. The rest is just inspection if this isn't happening
