Area of a circle is 3.14 x the radius squared
The volume of a cylinder is the area x length
Assume an average dia. of 470mm
[.235 x. 235] x 3.14 x 5
3.6 cubic m
err asuming timber was square at 0.5m x 0.5m that is a 0.25m2 x 5m = 1.25m3
i.e. W (0.5m) x H (0.5m) x L (5m) = volume
thus round timber of <500mm dia by 5m long must be less than 1.25m3
err asuming timber was squareat 0.5m x 0.5m that is a 0.25m2 x 5m = 1.25m3
But it isn’t square, its round.
3.6 cubic m
yes showing that its NOT 3.6m3 as you said given the square volume is still only ~1.25m3 then a cylinder MUST be less than that! :001_rolleyes:
Apologies, I had plugged in a longer cylinder and didn’t check the cut and paste
help !!!!!!!!!!!!!!!!!!!!!
so that wid work out the tree trunk if i was to sell it as fire wood will be
3.6 m3 no way dose that work out or dose it
Treequips equation was right he just put the wrong m3 ;)
475mm dia / 2 = 237.5mm (0.2375m) radius
[0.2375m radius x 0.2375m radius] x 3.14 π (short Pi) x 5m length = 0.885577m3 volume
using longer Pi its ~0.8863839285714279m3
Edited by b101uk
