Sorry this isn't really arb related but our oil fired Rayburn has suddenly decided to stop heating water... (oven part fires up as normal).  Think the boiler and oven are 2 separate burners?
When the heating/hot water should be on an orange light comes on at the bottom as per attched pic.
Have got an engineer coming (when he feels like it) but in the meantime no heating....
Just wondering if its a simple fix?  I've checked its not the pump/mororised valve.
Thanks
3 hours ago, Nopedigree said:
It is certainly a simple fix on my, albeit a lot older model, pressing the lit button resets the tripped condition.. and Bob’s your uncle.
NoPedigree
Ok wow thank you, will try that later!!
Thanks
We had to replace multiple PCBs with ours. Ended up sticking in an Esse Ironheart. Much better.
NoPedigree
Bob is ya uncle and it was indeed simple, what I thought was just a light is also a button... pressing it has sorted it👍😁
Thanks a lot NoPedigree much appreciated 🍻
Ok cheers for the heads up.  Haven't had the house long, will bear that in mind if we get loads of issues.
