If it's hydraulic feed roller then it could be a faulty valve block or solenoid allowing oil to keep trickling through.
When you disconnect the sensor wires do the rollers stop ?
No they keep going?
What about the solenoid block?.
That would be my first thing to check, usually two wires and a single retain nut. I tend to use a test lamp for such situations when scrabbling around fault finding tractor hydraulics.
Edited by GarethM
