I'm sure the experts will be along to comment.
Have you changed the spark plug/cleaned the air filter, that fixes a lot of issues for me?
Has someone messed with the tuning H screw badly or are they at the default setting?
Or it could be a crack in a fuel or air line somewhere, giving the wrong mix
Sounds like fuel starvation. Fit a new fuel line and fuel filter if not done in the last few years, strip the carb, check the gauze strainer for blockage. Reset the screws H and L to one turn out from fully in and see how it goes.
Pulling off the exhaust and checking out the piston is a good idea.
Agree with Spudulike. If you are confident enough, once you have checked fuel lines start it up, get it warm and put it under load in some wood- if it loses power and dies, take it out the cut and give the H screw a quarter turn anti clockwise (this will richen it up a bit at top end- then re try in the same cut. It will either be the same -in which case do more in depth checks as mentioned above, or it will improve things- in which case a carb clean/new diaphragms may well be in order, or it will cure the issue.
