I have just purchased a old Godin 342 Woodburner, it is in perfect condition, and has a 8cm exhaust outlet, what sized stainless steel chimney liner to I need, for such a small woodburner.
Same size as the outlet or larger, you can't go smaller.
But get someone registered to sort it, it's not worth the aggravation with building control and or dying.
Edited by GarethM
If it's an old wood burner it wouldn't be DEFRA approved so technically it could be it requires a 6" flue as at one time the minimum size flue for wood was 6"
Edited by slim reaper
