1 hour ago, spudulike said:
In my first post I said pretty similar......
"The first photo, sometimes but not always, there is a plastic or soft rubber tiny bung in the brass bit and if you prize this out, there will be a screw underneath which is actually the top of the barrel needle and you can richen the low speed running by undoing it a little. "
No disrespect......even my wife has problems keeping up with me, even after 30 years😉
You mean ive got to read everything in the thread...... damn..... And digest it..... double damn.
Nah, its ok - I was attempting (and failing obvs) to draw attention to the fact it was similar design to the other anti-tamper screw head.
OP was already on the case, knowing there was an adjuster there as well (post 1).
A belated good spot, most aren't aware there is often a needle adjuster located under a small bung. It often eases a poor idle on some machines.
Definitely well hidden....
On the few I've played with they seem bloody sensitive. ..1/8th turn either way and barely run...might just be cheaper end of the range though (Mitox strimmer, Oleo Mac hedge trimmer).
