11 hours ago, adw said:
This is fast coming down to excessive vibration, or poor quality springs in my opinion, I just cannot see a bit of wear on the crank journal causing this.
Ok well this is better news. Clutch assembly and three springs fitted were OEM to rule out aftermarket quality.
vibration would be :-
needle bearing old/worn
clutch drum old/worn
sproket old/worn
owt else?
Because i think there is an issue with springs sir, the 254 clutch is a different design and as you are on .325 and a short bar it may be a better option.
