Alright folks
I have a  clarke raider 15/1000 air compressor, not done an awful lot and in good nick.
Trying to blow a tyre up on sat and i had moved it to a different shed than usual and after a short space of time u heard air blowing out from it.
Its coming from the box where the on/off switch is and coming out the hole that the electrical power cable comes out.
I must admit i was stretching the cable a wee touch to get to the plug but not too bad.
Just wondering why air is leaking out there? Prob only 2 bar of pressure when it started leaking out. I can't imagine the elecrical cables are connected to the air circuit ?
Any ideas
From memory, my compressor had a similar thing.
Isolate the power and inside the box is a sprung loaded valve that switches the motor off wen it reaches a set pressure say 8 bar.
The outlet from the cylinder could have blown a bit of muck or rust up there and spoilt the seal.  Especially if it's not been drained of water
I jus let al the air out and unbolted the assembly and had a good clean up.
If that makes sense.
