Have recently purchased a Botex 360 2nd hand. Currently have it on an old 2140 Jd. I've played with the setup as it is around the yard and its very handy. Just wondering if anyone else has this model on a relatively small like the JD tractor? Its not going to be used for Forestry operations or anything too hardcore just larger Arb jobs where it will fit. The hydraulics on the JD run it fine just seeing if anyone else uses a 360 on a smaller tractor.
Ran a 360 for years until I wrote it off rolling the trailer it was mounted on in a forest ditch , it was an impressive little crane with a good lift capacity and reach.. wish I'd kept it and got it roof mounted on the valmet 6400 as they would of been ideally suited.
Currently running a 580b and the 360's lift wasn't far off it.
