Is this sound normal. I appreciate the metal has to expand etc. but it happens throughout the burn. You can hear it from other rooms quite clearly. Is something lose? I have tightened the rear plate and Alan keys inside. If so, how would I access it.
Once its up to temp it should not make that sound . Mine hardly does it at all even when warming up . What make is it ?
  • 4 weeks later...
I would not do everything up tight, just enough to hold it together.. remember, cast iron might be strong in compression, but it is very weak in tension, you want the thing to be able to move or it will crack..
john..
