Hello iv got a husqvarna 129LK and wanting to put a Polesaw attachment on it to do a bit of high sawing at times, but the price of them are way out of my range and can't justify paying it for the amount of time it would be used, is there another alternative make that would fit my machine? Thanks in advance
Might be worth asking at your local dealers if they have a second hand one that,s any good
It is usually a case to see if you can pick up a cheap Chinese one with the same drive shaft end type - splined (number of splines), square (Across Flats), inner shaft diameter and the same outer shaft diameter although the later can be shimmed up with thin plastic sheet, paper etc.
I may have a pole saw attachment going spare shortly, as its not getting much use these days. Its 10" bar with brand new oregon chain on it.
If memory serves its 9spline, but you can get adapters on fleabay.
Steve
Steve
