Evening all.
My iveco truck alarm is too sensitive and keeps going off. When it does this it's lights continue to flash till it is reset, which then drains the battery... and when the battery drains the alarm will then stay on continuously.
I was thinking can I lock the doors by key in the door method without using the fob to set the alarm.
Hopefully hear from all you people in t'internet land soon, as last night at 2am it weren't much fun trying to sort it out.. had to put power to the battery, yes that was really good fun!:thumbdown: with the alarm blaring out in a residential street.
Try setting the heater to recirc before switching off and make sure all windows etc are shut tight. If it`s windy park in a sheltered position. Most alarm triggerings are down to the volumetric sensor inside the vehicle.
in my car, ive a little black box in the engine bay with a small rubber cap covering a key hole, on the keys, ive a small key, the small key turns the allarm off, but keeps the remote central locking and immobiliser function working
