Cant quite be sure from your pictures, but is the carb a double barrell unit? It looks like its two carbs in one casting? If it is then I guess its got two separate chokes and two separate sets of jets? Either of them could be blocked/not working which could upset the single cylinder. Some of the previous posts have said it wont be a carb problem cos its a single carb/barrell shared by both cylinders, but that doesnt look to be the case?
  • Replies 33
Spot on, you found the thread and more importantly found the carb breather, my work here is done, happy chipping. I have a dome headed filter in mine but anything would-be an improvment. Now all you need is a muck truck with greedy boards.
Well I've done the carb strip and guess what?! Crap in the "infamous emulsion tube / breather" ! As I blew it out and sprayed in cleaner, bits of wood fell into the throttle body and branch section. That Ozzy knew his stuff eh! I have put a little foam into the hole. Checked the earth on the spark controller / coil earth - seemed fine. Still haven't done valve clearances but that's because I have to start the machine to reverse it out to work on it so no longer cold enough! Thanks again Bushy...:001_smile:
  • 3 months later...
