6 way diverter valve help and how to change hyd circuit over from hammer?!
swinny
Hi all, in a bit of a pickle and need a bit of direction if you can please?
I've fitted a 6 way diverter valve to my aux circuit to run a grab and rotator.... currently with having done nothing to change hyd setting I have a functioning grab :) 😀
My question is should it actually work if oil should only flow one way on hammer setting? Anyhow it does.....
Just spent the last 2-3 hours messing about running wires etc to the solenoid so I could try rotate function.... nothing! Bugger.... then as I was giving up I could try the grab then flick my switch and the rotator  would move a few degree and stop.....
I'm wondering if I've got the diverter piped right? .
I think I have and that it needs the circuit changing over from hammer to 2 way?
Not a bloody clue where it is though :( 😞 aanyone know? Dont know why it can't be easy to spot and get too....
Many thanks for your help.
Chris
