Just putting this out there…..
If it were mine, or if I was advising a client, I think I’d be inclined to take the hedge out altogether and replant with a different species.
You could try and eradicate the caterpillars, but they’re obviously in your area - so they will come back, you won’t get them all - so your hedge will always be declining and scabby, and it will be a constant battle to maintain a poor hedge.  Plus applying noxious chemicals into the wider environment isn’t good.
Alternatively, you could plant a new hedge this autumn and spend the next few years watching it come into fruition and maturity.
The first option is negative, time consuming and involves nasty chemicals.  The second, whilst initially drastic, is positive and ultimately rewarding.
I'd go with this suggestion. It will probably be a constant battle with the caterpillars from here on in. And if they don't get the hedge then Box Blight will! I think Box's days as a hedging material are numbered sadly.
Earlier this year there was a feature on Gardener's World about suitable replacements to Box. I can't remember the episode but it was a few months ago, I'm sure you can find it. It turns out there are actually quite a few good alternatives. I forget the name now but I think the favourite was a NZ plant.
Have it out, it will be cheaper in the long run to replant now than try and battle to keep it alive to then fell and replant in 2 or 3 years time. By which point the new hedge will already start to look something instead of a crap box hedge followed by another couple of years of the new hedge establishing.
